IHC Little Genius Plows
Rick in Pa
08-30-2006 09:40:43
I have two Little Genius plows, one is a two bottom the other is a single. Both are complete but need a little help. I want to make one good one from the two but I'm not sure which is the more desirable plow, two bottom or single. It will mostly be used for show with the occasional use in the field. Which way should I go?
RustyFarmall
08-30-2006 10:37:58
 Re: IHC Little Genius Plows in reply to Rick in Pa, 08-30-2006 09:40:43
The single bottom would be the most rare, the 2 bottom the most useable. How about shopping around for the parts you need and restore both of them?
Tim(nj)
08-30-2006 10:08:10
Well, all the shows and auctions I"ve been to, I"ve seen more 2-bottom Little Geniuses than I can remember, but I"ve only ever seen 1 single bottom at a show, and 1 at an auction (maybe it was the same plow???). I suppose this is because so many more Hs were sold than Bs, and many Bs used a mounted plow. Then the C came along with Fast-Hitch. So from a spectator standpoint, the 1-bottom would have more interest to me.
Gwiz
08-31-2006 18:17:52
 Re: IHC Little Genius Plows in reply to Tim(nj), 08-30-2006 10:08:10
How many have you seen with slatted bottoms?
Tim(nj)
08-31-2006 20:40:07
 Re: IHC Little Genius Plows in reply to Gwiz, 08-31-2006 18:17:52
Only one 2-bottom that came out of the mucklands up near Pine Island, NY. I have also seen a 2-bottom Ferguson slat plow, a few JD slat plows, some newer, some older, and a few IH Fast-hitch and A-C snap-coupler slat plows. Most of these came from Pine Island, NY area.
