Parts for a JD B Drill
John Bukowski
02-16-2000 10:08:14
Hello,
I have a JD / Van Brunt B grain drill with grass seeder. I would like to use the drill this spring to plant oats and red clover seed. The grain portion is in good shape, but the grass seeder is missing the small flexible tubes to allow placement of the seed in the disk openers or to broadcast. JD no longer supplies those small tubes, and I can only find universal replacements for the grain tubes at my local farm supply store. These rubber replacement tubes are much too large in diameter and too short to work on the grass seeder. Does anyone have an aftermarket source or know where used ones can be purchased? I need all 16 tubes for my drill (och!).
thanks
john bukowski
Leon
02-17-2000 06:13:12
 Re: Parts for a JD B Drill in reply to John Bukowski, 02-16-2000 10:08:14
I also own a B but I was told that when seeding grasses or clover from the grass seeder that you should leave the seed tubes off and let the seed fall out of it from the top. Unless you are overseeding like in sod or pastures or whatever, the clover seed may get to deep in the ground by placing the seed tubes in the disc opener. This is true if you have very loose soil you are planting in. I would just let the seed fall on the ground and let the drag chains cover it behind. It works very well that way. Leon
John Bukowski
02-17-2000 14:01:22
 Re: Re: Parts for a JD B Drill in reply to Leon, 02-17-2000 06:13:12
Thanks Leon for that simple solution!! I will be drilling oats, and thought it best to scatter clover seed on top. If I had tubes, I would have placed them behind the double disk openers and before the drag chains. I did not think about just letting the seed fall out the feeder cups onto the ground. Should work just fine. In fact, I think I will use this method to broadcast clover in my winter wheat.
I might still try to find the tubes (or make something out of the garden hose) in case I want/need to plant grass with grain someday using the openers.
Tim(nj)
02-16-2000 17:47:36
Just looking through my FB manual . . . .
I would try to make my own out of clear plastic tubing.
Or, you can ask you Deere dealer to show you a plastic drop tube for a grass seeder off a 450 drill. I think it's the right diameter. It's long though, you'll probably be able to make a few out of it for the B.
Burrhead
02-16-2000 18:39:08
 Re: Re: Parts for a JD B Drill in reply to Tim(nj), 02-16-2000 17:47:36
The clear tube works pretty good and aint too expensive.
I take my tubes off for clover, rye, and timothy.
