Krause disc
TPIA
08-29-2006 05:51:10
Looking at a krause 2416 rockflex disc . Can anyone tell me about what years they were built ? and do they ridge or disc fairly level thanks TPIA
MSM
08-29-2006 09:20:06
 Re: Krause disc in reply to TPIA, 08-29-2006 05:51:10
I would guess it was built in the late 90's. If it is set up and adjusted properly and you don't try to harrow too fast it will give a nice level finish. What size is it? We used to pull a 26' with a packer behind a PTA325 Steiger with no problem.
TPIA
08-29-2006 11:03:48
 Re: Krause disc in reply to MSM, 08-29-2006 09:20:06
It is 26.5 ft I plan to pull it with a CIH 9150 280hp Should it pull it ok @6mph? .I used to have a ST270 Thanks TPIA
IaGary
08-30-2006 04:34:57
 Re: Krause disc in reply to TPIA, 08-29-2006 11:03:48
Yes you will play with it.
Unless you plan to put in the ground to the spools.
I pull a 25' disc with a MX200 with 175 hp with no trouble.
Gary
TPIA
08-30-2006 19:00:31
 Re: Krause disc in reply to IaGary, 08-30-2006 04:34:57
Thanks Gary I figured it would pull it as i pull a 24 ft white 271 and it dosen't even know it is back there TPIA
