PTO Shafting hard to get.
bjr
08-28-2006 14:08:43
Good luck in finding correct tubing locally, unless in or near major city. PTO tube has to be able to slide into each other and standard of the shelf rectanular tube has a inside seam that won't let that hamppen. Most retail stores can "order it". Try Agr-Supply for complete unit. I know the pain of peice mealing a PTO shaft. Buy the complete thing and be able to get back to farming a lot quicker. bjr
Keith In Kelseyville
08-28-2006 14:36:25
 Re: PTO Shafting hard to get. in reply to bjr, 08-28-2006 14:08:43
The part with damage is the outer sleve of the PTO shaft about 12 inches down from the U joint on the tractor side. The pipe is like a 2" with a rectangular part allowing telescope entry of a rectangular shaft in the other end. It only damaged the round pipe. I was hoping for a quick fix, but probably easier and cheaper to replace...if I can find a replacement. Thanks, Keith
