Roller pressure adjustments for a NH 467 Haybine
Isidore Flores
08-26-2006 15:50:04
I just got a NH467 Haybine and I can't figure out how to adjust the roller pressure. The picture and directions in the operator's manual do not match the machine in that the roll tension adjustment bolt is not where the picture shows it to be! Could parts be missing or the unit produced early in the model run when the design had not yet been made final? The machine's serial number is 111135. Can anybody set me straight and free me from my delusional state?
Duane in MA
08-28-2006 06:12:57
 Re: Roller pressure adjustments for a NH 467 Haybi in reply to Isidore Flores, 08-26-2006 15:50:04
My 467 is the same. The adjustment is actually in the middle under the cutting head accessable from the back with everything lifted. Ther is a large bolt with two or three nuts. Turnining the bolt adds or reduces tension to the torsion bars. If you do some old searches you will find some problems with these torsion bars rusting in place. Good Luck, Duane
