Microwave Moisture Test Question
Mark (PA)
08-25-2006 17:51:49
Hello,
I have never tried the microwave moisture test before so I thought I would give it a shot. I have a postage scale to use. Maybe not the best but accurate anyway. So I read to put on 10 ounces. How do you get 10 ounces on a paper plate???? I had it overflowing with about 1.3 and 1.0 ounces respectively. Granted I didn't try to pack it down either... maybe I should have? So I ran the test and came up with 18.2% and 17.3% on my samples. Chance of a t storm tomorrow afternoon so I really would like to get the hay up prior to that.
Can anyone shed some light on what they use to hold the hay in the microwave other than maybe a paper plate? Just can't seem to get much on so I assume that affects the accuracy of the test?
THe hay has sat for 3 full days in 75 to 85 deg sun. ALthough we are having some heavy morning Dew lately.
I think its probably ready. Just looking for some help on the test and if my test is accurate with such a small qty? I plan to try a sample around 9am or so and see if its a go.
Thanks Guys
Edd in Ky
08-26-2006 18:31:10
 Re: Microwave Moisture Test Question in reply to Mark (PA), 08-25-2006 17:51:49
Just one more quick comment. This forum is of great value to people like me, long away from farming, just back at it , having fun and trying to learn.It is so great that guys like the KYhayman has so much knowledge and he is willing to share with everyone. I just went back and pulled all his advice on making hay, shared on this forum, in the last 3 years. I don't know where else you could get such thoughful and experienced advice for free. Sure has helped me understand making hay. Thanks KYhayman.
Joe/pa
08-26-2006 15:33:00
Have you tedded the hay or has it just laid in place since you cut it? Chances are depending where in PA you are 3 days drying and you'll be ok. Even with the heavy dew 3 days does mine, but I ted to keep it up off the ground.
Edd in KY
08-26-2006 15:13:38
Since we are all sharing ideas here, thought I would add 2 more little things I've learned.
When the hay feels fairly dry and ready to bale, wait until the dew is off and it is really dry on top (usually after noon in KY), then rake it so it rolls up soft and the air can blow thru the windrow. Try to move all the hay, so none of the hay under the windrow is still on the ground where it was cut(holding ground moisture).
Start baleing on the first area you windrowed, which has given that hay a while to dry the underside, and as you finish the field all the hay in the windrows will have had a few hours to dry.
Especially around here where the sun is very hot and the wind often blows, a couple hours in the windrow will dry the hay a lot.
kyhayman
08-26-2006 15:09:58
I've been using 10 grams, and set the scales for metric.
hayray
08-27-2006 05:51:10
 Re: Microwave Moisture Test Question in reply to kyhayman, 08-26-2006 15:09:58
I would figure the microwave test to be more accurate, but is it more practical than using a moisture tester?
spitz
08-26-2006 06:55:46
When is college we used an oven on low heat instead of the microwave. Microwaves are supposed to have stuff with moisture so they dont burn up! Dont need the wife on yer case!
Gerald J.
08-25-2006 19:39:25
Last time I tried that, I used a small analytical balance and a clean foam coffee cup.
And when I got it done a few times that day, it agreed with my feeling tests. When the microwave test said the hay was ready, the hay felt ready and not before.
To test by feel, I grab under the windrow. If it feels damp, its too wet. I grab a bundle and twist it. If its tough, its too wet, if it snaps off its plenty dry. Seems the toughness of the hay kind of matches the moisture content.
Gerald J.
Mark (PA)
08-25-2006 18:53:24
Thanks Joe and Edd
I will bale her up tomorrow. Hope to start early at it really because rain is due late afternoon/evening. I'll let you know the results!
Joe in IN
08-25-2006 18:39:22
I think 10 ounces is WAY too much to use. Thougha larger sample size will lead to better results, of course 10 ozs could invoke the law of diminishing returns....
Try 1 ounce or even .75 ounces. SOunds like your results were reasonable, use a smaller amount, some might not have gotten dry...
Bale it....(though at this hour probably too late...)
Edd in Ky
08-25-2006 18:21:37
Yep....tried that micro wave test too. Was immediately ordered out of the kitchen, and other important rooms. I could not make it work either.
Ask a local farmer with experience to come feel and smell your hay. Odds are after 3 days it is fine to bale. There is a lot of art in hay making. The experienced old timers understand it naturally, the rest of us watch, ask advice and learn as we go.
