John Deere 14T Baler knotter removal
oldnnew
08-24-2006 19:25:20
Hi all,
Need to work on the knotters on my 14T. Had a severe needle mis-hap which resulted in broken needles, bent needle arm which are both fixed now. (Baler went out of time and the wedge the comes up in the bale chamber to stop the plunger and shear the bolt was jammed up with a stick, thus wasn't able to rise...bye bye needles!) I also noticed that a tab is broken off on one of the knotters that holds the twine discs in place. I need to get the knotter off and the tab welded back on. How the heck do I get the knotters out?? I know there is a bolt that holds them in place, but how do I slide the main shaft out that they pivot on?? Any help would be greatly appreciated!
Thanks.
Joel Harman
08-25-2006 07:10:42
 Re: John Deere 14T Baler knotter removal in reply to oldnnew, 08-24-2006 19:25:20
By the cam (rt side)that trips the knotters there is a pin that goes through the middle of the shaft. Pull it. Keep track of the shims. Shaft comes out on flywheel side.
oldnnew
08-25-2006 01:59:26
"Remove in accordance with your manuals instructions. After repair re-time baler according to the instructions provided in the same manual. Good luck..... ....."
BobMo-
You can check your attitude at the door..... .thanks.
oldnnew
08-25-2006 01:54:36
Ok, I have an operators manual, so I have the instructions on how to time the baler, but it says nothing about disassembly of the knotters. Which manual do I need?
old
08-24-2006 20:49:10
BTDT and thats why I have a junk baler on the place. When that happen to me it broke the knotter so I could not fix them with out more $$ then it cost to buy another baler.
BobMo
08-24-2006 19:44:03
