tightening worm gear on the shaft?
mike kinsella
08-24-2006 12:51:23
after adjusting twine disc timing on knotter I am having difficulties tightening the worm gear fully against the shim- i know the shaft is tapered and i wedge the pinion against the knotter frame as per manual but the nut gets so tight and gear dont move up am afraid to strip the thread --any ideas out there,Most grateful for any info.
Blue Buddy
08-25-2006 18:48:05
 Re: tightening worm gear on the shaft? in reply to mike kinsella, 08-24-2006 12:51:23
when ya tighten the nut, it shoves the gear on the taper and locks the gear to the shaft in place, the shims are there to control end play, if you tighten it and still have space, remove gear, add shims, tighten, and check till you get the right amount of end play, basically just enough end play to not bind the shaft and gear as it turns
Joel Harman
08-25-2006 07:19:42
My 272NH did this few yrs ago...manual said replace the shaft
