McCormick 27 baler needles
TomW
08-20-2006 07:28:52
I have a McCormick 27 baler that wants to tie on every plunger cycle. The plunger stop works fine as did the sheer bolt. The operator's manual says something about adjusting the trip sheave support but does not tell me where that is. Is the trip sheave a likely cause and if so where is it?
Thanks
GeneOliver
08-22-2006 07:48:18
 Re: McCormick 27 baler needles in reply to TomW, 08-20-2006 07:28:52
I'd take a look at the spring that holds the trip lever against the clutch trip. Mine was stretched and caused it trip every time I hit a rough spot on the ground. Remove the spring and it cycles on every stroke. If all this is ok, pull the clutch and check for frozen or broken parts inside the hub. There's a trip dog inside the hub , held in place by two bolts. It may be broken loose and not allowing the clutch to release.
Now..if I can just get mine timed in right, we'll all be making hay..
Gene
