ROTOCUTTER
sssss
08-19-2006 03:34:26
Anyone heard of a ROTOCUTTER bush hog made in Lilliston GA. It is a trail behind type. Need spindle bearings, any help appreciated. thanks
a_lead
09-11-2006 17:50:02
 Re: ROTOCUTTER in reply to sssss, 08-19-2006 03:34:26
The mower you describe is most likely a "Lillliston 7-6". I have been looking for parts this summer for the 1 that I have also; Have found that at one point Bush Hog had owned or bought Lilliston, and that any dealer that carries B.H. should have belts, bearings and blades.
The Bush Hog dealer that I bought blades from several weeks ago showed me some info that may help; ATMAX Equipment in Wimauma FL (888-512-8873) www.atmaxequipment.com, makes the "Mathis SD 75 Lift and Tow Mower". In the literature it say "Was Formerly Lilliston 7-6" & HOL-MAC 7600 (7-6 parts available) cross referenced.
sssss
09-13-2006 18:10:34
 Re: ROTOCUTTER in reply to a_lead, 09-11-2006 17:50:02
As I said matched bearings by size- the ones I could get were lifetime sealed and hopefully will last as I don't plan on using it that much. Itworked out well since on seal seat was worn tapered and would not have held a seal anyway. good luck
Coloken
08-19-2006 07:36:59
Bearings are usually of a stock size. Take them out and look for numbers on them, then to bearing supplier house. Cheaper too most of the time.
sssss
08-20-2006 05:26:36
 Re: ROTOCUTTER in reply to Coloken, 08-19-2006 07:36:59
Yep, did that, they are Hyatt bearings and they couldn't match #'s so now we are doing it by sizes. I deal with a company that will sell to me wholesale as I have a construction co. and buy bolts and hydralic parts ect. Thanks anyway just looking for easiest way to fix.
