cycle bar mower install?
Todd A
08-18-2006 21:31:44
I have a 58' cub lo-boy and a IH 104 cycle bar mower. Does anyone know if these are compatable with each other? If so where can I get some directions to install it on the tractor. I can see by looking at it that the mounting brackets will line up but I am lost on how to connect the pto.
Todd A
08-21-2006 19:33:39
 Re: cycle bar mower install? in reply to Todd A, 08-18-2006 21:31:44
You are correct on the mounting, and I will check out the website. Thanks
Jim Broughton
08-18-2006 21:48:19
I'm not familiar with the 104 mower, but the Cub lo-boy uses a pulley on the PTO,with a steel pin that goe s through to lock it on.With the pulley in place, you use a v-belt to the mower via a shaft that goes under the tractor to the mower in front, at least that is how mine works ! I'm assuming the 104 mower is mounted just ahead of the rear tires, and bolts with a yoke to the underside of the engine.(Mine is a regular 5 foot Cub sickle mower) Anyway, lots of luck ! Jim B.
