2 hay rakes
MattLobdell
08-17-2006 18:21:03
I am looking for some good pictures, or plans, or both of a device used to tow two hay rakes at once. I have seen only one before. I would also be interested in knowing who may have manufactured them. The particular one I saw raked 2 seperate windrows with two rakes at once. It had a hydraulic piston on it that somehow attatched to an axle in the back. When the piston was actuated one way, the axle would turn some how and the device would "open up". When the cylinder was actuated the other way, the device would close and bring both rakes in single file for road transport. Any info would be greatly appreciated. -Matt
Seth_ia
08-18-2006 20:40:40
 Re: 2 hay rakes in reply to MattLobdell, 08-17-2006 18:21:03
What you want is a hydraulic bridge hitch. Kelderman MFG. makes one. They are about $2000 new. I just missed buying a nearly new one for $500. I now plan on building one from an old rear combine axle.
Eugene SWIA
08-18-2006 17:36:35
I have a rake hitch for sale. Also have a right hand rake for sale. At Audubon Iowa 712 563 4115 Gene
Tn Ford Farmer
08-17-2006 20:34:04
New Holland and New Idea both make hydraulic rake hitches. NH model number is 252. I made the one I use for about $1250.00 8 years ago. I borrowed a friends NH one winter and built mine. I have 2 NH 55 rakes that I use. Cuts your raking time in half. I cut with a 1411 discbine and in very good hay I rake a width and a half of the 1411. In good hay I rake 2 widths and today I raked 4 widths of a 1411!! It takes a little getting used to making a turn at the end but I wouldn't go back to a single rake by no means. This year on 2 different times, one of the rakes has broken down and I went a borrowed a rake to finish. I have seen a right and left handed rake pulled with this hitch.
730virgil
08-17-2006 19:57:03
new holland made such a thing once upon a time
