Hydraulic cylinder -Single hose to double?
shawmic
08-16-2006 07:38:59
My gopher getter implement has only a single hose hydraulic cylinder. It lifts quickly but has delay going down and into the ground. Is there any reason that I can't put a double hose cylinder on instead so I can get down pressure?
IaGary
08-16-2006 07:50:16
 Re: Hydraulic cylinder -Single hose to double? in reply to shawmic, 08-16-2006 07:38:59
They may have put no down pressure on it for reason.
But what are you pulling it with?
Some tractors have a valve you turn to use on one way pressure so the oil will return quicker or easier.
Gary
shawmic
08-16-2006 08:36:50
 Re: Hydraulic cylinder -Single hose to double? in reply to IaGary, 08-16-2006 07:50:16
I am using a Ford 3000.
souNdguy
08-16-2006 12:13:34
 Re: Hydraulic cylinder -Single hose to double? in reply to shawmic, 08-16-2006 08:36:50
What are you using for a spool valve? Does it have provisions for a DA cyl?
Soundguy
