IH 2400 baler bearing
Nathan (SD)
08-15-2006 21:32:00
Does anyone have the bearing no. for the rear bearing on the big flat belt in the bottom of the baler.
IaGary
08-16-2006 07:04:39
 Re: IH 2400 baler bearing in reply to Nathan (SD), 08-15-2006 21:32:00
Nathan
That is probably just a plain lock collar bearing.
Measure the shaft size and out side diameter,most bearing shops will have the
bearing you need.
Differant bearing manufacturers use differant numbers for the same standard bearings.
Gary
