post driver hydraulic lines
derek mcpherson
08-15-2006 15:35:03
Hi, I just purchased a shaver hd-8 post driver.
I have never been around one before. On the lines that run to the tractor, the ends are threaded. Can I install quick connects? & doesn't
it hit harder if i run the return into the hydraulic resoivor fill hole?
Dave Sherburne NY
08-17-2006 19:34:45
 Re: post driver hydraulic lines in reply to derek mcpherson, 08-15-2006 15:35:03
You do want to run that return line directly to the
fill hole on your resivoir. You have to get that oil
out of the cylinder as quick as possible in order
to pound posts Don't put any restrictions on the return line. That return line will try and jump out
of the fill hole if you don't have something to hold
it in .Eventually it will jump out and spray oil every where.
Bill pa
08-17-2006 06:47:30
you dont want to go directly from the post driver to the fill hole on your tractor because that will be by-passing the hy. filter whitch is on the return line of the tractor system, on the low pressure side(return line) Bill
BobMo
08-16-2006 06:55:07
Rob is correct. Also if you didn't get a connection specificaly for your tractor to the fill hole(return line) you'll need to get one. If you bought this new they should have supplied one for you otherwise you can order one from Shaver. All you have to do is give them your tractor information. This is a great piece of equipment..... ..Good luck & be careful....
Robhkent
08-15-2006 18:42:25
Derek,
The small line running from the valve is your supply line, the large line is the return. The return needs to be plumbed into the reservoir. It will not work if you hook it into the other side of a two way hydraulic system. Yes you can put a quick connect on the small line, hook it up to one side of your hydraulics.
When you are getting ready to use the driver run the ram up and down a few times, longer stroke each time, this starts a little stretch in the springs and will make them last longer.
Just a little safety tip here.. never for any reason put your hand on top of a post ever!
derek mcpherson
08-16-2006 15:39:03
 Re: post driver hydraulic lines in reply to Robhkent, 08-15-2006 18:42:25
Thanks a lot guy's. I really wasn't sure
what to do hehe. I am a fence contractor
& am thinking this will decrease labor cost,
save me & the customer time, & hopefully
boost profit. Thanks again & take it easy.
Robhkent
08-17-2006 06:25:00
 Re: post driver hydraulic lines in reply to derek mcpherson, 08-16-2006 15:39:03
Derek,
I build a fair amount of fence every year, and I build most of it alone. One man with a #8 driver and a digger, plus the other tools, can build 80 rods of fence alone in 2 days. Thats a 5 barb, 2 steel and 1 wood with corners at each end.
Rob
PS You have to hustle to do that, but I have done it several times.
