manure spreder chain
jack-iowa
08-14-2006 14:34:14
On the chain that pulls the manre on the bottonm of the wood I had a bar break and got it all replaced cept cannot get the links close enough to connect them . Any tips or ideas?
thanks
farrviewsouth
08-15-2006 16:48:44
 Re: manure spreder chain in reply to jack-iowa, 08-14-2006 14:34:14
On this note, can someone tell me which way the links should face and the same for the cross bars.
Does the "L" face toward the back or front of the spreader
Thanks
Don-Wi
08-16-2006 00:17:09
 Re: manure spreder chain in reply to farrviewsouth, 08-15-2006 16:48:44
The upright of the angle iron slat goes toward the back.
Donovan from Wisconsin
farrviewsouth
08-16-2006 16:25:38
 Re: manure spreder chain in reply to Don-Wi, 08-16-2006 00:17:09
Thanks for the quick reply
730virgil
08-14-2006 17:57:25
there should be some kind of tightener at both front corners of spreader back these off as far as you can
jack-iowa
08-14-2006 17:27:57
Thanks all, will get the come along back out and see what happens.
Illinois Farmall
08-14-2006 15:14:11
A come-a-long works best for pulling the spreader chain back together so you can get enough slack in it to drive the chain links back together. Hope this helps.
Hurst
08-14-2006 15:13:20
On our big spreader, we have to take the chain off the front slides (or idler sprokets if yours has those instead), then once it is together, loosen the slides to the position with the most slack, then using a couple of crow bars, slowly pry the chaing up from the bottom a little bite at a time. What you are doing here is taking the slack from the bottom where it droops. Another way to fix it is to use one of those tie down things that the big truckers use to tighten their chains (I cant think of the name right now)and wrap a chain around 2 bars close to the chain on the side you want to pull together (so you don't bend or break the bar) and tighten until you can fix it. Good luck and let me know if you have any more problems or questions.
Hurst
Stickler
08-14-2006 16:31:54
 Re: manure spreader chain in reply to Hurst, 08-14-2006 15:13:20
On a side note here..... .how much tension should the feed chain have. I just got done getting my auction special fixed. Bought with broken chain links and bent bars. Chain guides underneath had been installed wrong, and it was breaking links every time it was used. It works good now, ran about 60 loads through it the other day, but I never had one before so I am ignorant. I have it tensioned so the chain has about an inch of movement at the bottom end of the drive sprocket to the lower frame.
Hurst
08-14-2006 19:46:34
 Re: manure spreader chain in reply to Stickler, 08-14-2006 16:31:54
Well, I am definatively no expert on that. Our spreader, which is about 18 ft long, does not have any supports that work underneath of it now and I have run about 20 loads through it without breaking a chain. It is more vulnerable to snagging and breaking though when it hangs that low. I hope to get some made up before I head back to school though. I would think that you should have one in about the middle of your spreader, or if it is over 15 ft long, 2 that are evenly spaced is how ours were originally set up. Good luck
Hurst
