Chisel Spacing
Jim Allen
08-13-2006 06:30:33
A while back I bought an 11 shank JD 100 3-point chisel to use behind my IH 826. It had 1 foot spacing between the chisels. Knowning my 826 wouldn't quite pull 11, I turned it into an 8-
shank, still with 12-inch spacing. My questions.
1) If the chisels are closer together, does the unit pull easier?
Like a moldboard plow, e.g a 3-14 vs a 3-16.
2) So, assuming it does, if I decerased spacing to, say, 8 inches (or whatever), and added the three chisels back, would it pull about the same in my clay as it does now with eight?
3) The reason Why I' thinking about this is that at different times, the chsiel plow will leave ridges between the chisels. It's not a huge issue, because I go over the ground two opposing directions, but I'd like to maybe eliminate that second go-round by doing it better the first time.
4) What are, in your collective opinions, the ideal chisel plow spacings
Many thanks.
IaGary
08-14-2006 19:18:48
 Re: Chisel Spacing in reply to Jim Allen, 08-13-2006 06:30:33
Jim
Just want to clarify one thing.
3-14s don't pull easier than 3-16s because there closer together.
They pull easier because you are turning 6" less soil.
3-14s are 42" wide and 3-16s are 48" wide.
Gary
paul
08-13-2006 06:56:43
What you want to do might work, but I don't think it will help for the ridges at all.
Idealy, chisel plow is designed for 12" spacing. It lifts & shatters the ground (only chisel when it is fairly dry, no mud). You should not really ever need a second pass if things and conditions are working right. It simpley does leave ridges. A chisel is a primary tillage implement, it will by nature leave a rough surface.
Follow with a harrow or field cultivator to leave a smooth surface.
If you want to do it all in one pass, attach a harrow bar to the back of your chisel plow - that will knock down the ridges. The chiesel itself won't really ever make things better - it's designed to fracture & lift in bigger chunks.
imho. --->Paul
