International 2MH corn picker
Lance R.
08-12-2006 21:30:37
I'm thinking about buying a 2MH picker for my 560D to pick about 15 acres of corn. Will this picker have a big enough capacity to handle today's yields of 175 to 215 bu per acre?
MN Scott
08-13-2006 07:09:21
 Re: International 2MH corn picker in reply to Lance R., 08-12-2006 21:30:37
I have a 2MH mounted on a Super M and it will handle 200 bu corn but just barely. The main trouble is lack of power when pulling a heavy wagon in the hills around here. A 560 would have no power trouble and it should work just fine for 15 acres. I would suggest you buy a parts machine or two thou as parts are no longer avaiable from CIH for these machines.
Princeton Bill
08-13-2006 05:21:38
Are you going to leave the picker on the the 560?
Mounting a 2MH and taking it off for 15 acres is a lot of work. I would consider buying a used pull type. If opening the field up is a concern with a pulltype, maybe you could havesomeone run through it with a combine.
Lance R.
08-13-2006 16:52:42
 Re: International 2MH corn picker in reply to Princeton Bill, 08-13-2006 05:21:38
I know it's a lot of work but I have the time and it's good for my sanity to have a throw back day to share the past with this younger generation. I was just wondering if the elevators to the husking beds could handle that much corn since they are significantly narrower than the 2MHD picker which I can't find.
MN Scott
08-13-2006 19:44:23
 Re: International 2MH corn picker in reply to Lance R., 08-13-2006 16:52:42
The side elavtors have no trouble keeping the ears away but if you are going down a hill corn will bunch up were it dumps into the rear elavator. Doesn't plug up but it makes a pile that goes down when you get on level ground again.
paul
08-12-2006 22:35:19
For 15 acres, should work out. For 150 acres, I'd give a lot of thought... ;)
--->Paul
