Separating a frozen PTO shaft
Timesup
08-09-2006 14:18:07
I could use some hints on separating a pto shaft.It has sat outside for a few years and now i can't pull them apart
paul
08-10-2006 08:09:07
 Re: Separating a frozen PTO shaft in reply to Timesup, 08-09-2006 14:18:07
I could make a dualed TW-20 (145hp, weighted) spin & not do a thing to a short pto shaft. They can freeze up good.
If other things fail & the shaft is collapsed as short as it can be, you may need to sacrafice the outer shield, and heat the shaft directly. That will get it free.
Note that a shaft can twist & lock itself up, it may not be rusted tight but just plain wrecked.
--->Paul
Don-Wi
08-09-2006 21:04:00
What's it on? We've always been able to remove the shaft form the implement and pull it apart useing a tractor and going very slow so nothing pops and flies at you. For us, it always seems to be the silo blower's PTO after they sit around for a while before we buy them.
Donovan from Wisconsin
timesup
08-10-2006 08:07:39
 Re: Separating a frozen PTO shaft in reply to Don-Wi, 08-09-2006 21:04:00
it from a hay baler.as of now i'm hanging the weight of the baler from a frontend loader with a chain around the shaft.i think it's given about an inch so far.
paul
08-10-2006 21:59:43
 Re: Separating a frozen PTO shaft in reply to timesup, 08-10-2006 08:07:39
Generally once it moves, with penetrating oil it will keep on going, should be easy once you get any movement at all.
--->Paul
Don-Wi
08-10-2006 17:58:40
If that's the case, it may be twisted like the other guy said. It should be able to pull apart if the sheilds are over it.
Is it new to you? could be a reason why they sold the baler...
RodInNS
08-09-2006 14:53:51
That would depend somewhat on what type of shaft you have. Most often it's the metric shafts that stick like that. I try to get some good penetrant on the shaft tubes. Spray it down inside from the end too. Then take a good hammer... say 1# +. Tap on the yolk and see if they slide apart. It not, then I would remove the shaft from whatever machine it's on. Chain one end to an solid object, and the other end to a tractor. Put some strain on it. If it doesn't give easily, then keep the strain up, and then go back to tapping on the yolk..... After that, I go to heating the outer tube. I haven't had that fail yet, but I don't have a lot of stuck shafts either, so I wouldn't be an authority on the subject. Good luck.
Rod
Oldmax
08-21-2006 06:10:26
 Re: Separating a frozen PTO shaft in reply to RodInNS, 08-09-2006 14:53:51
I had a shaft to stick tried everthing I could think of to get loose finely hooked to winch & to back of utility trailer two blocked winch pulled apart while tapping on shaft turned out the shaft was twisted just junked it .
