New Holland Square Baler Operators Manual
dev
08-09-2006 07:19:17
Hi, Just wondered, if anybody has posted the section from the new holland operators manual which explains how to adjust the knotters and solve knotter problems on the web?
I think the knotters are very similar on the 370, 270, 375, 275 balers so this section would be common to most of the NH balers.
Cheers....
dev
08-10-2006 02:09:41
 Re: New Holland Square Baler Operators Manual in reply to dev, 08-09-2006 07:19:17
Thanks for all the reply's...
Just was really stuck for it at the moment and though I might be able to print if off quickly. One of knotters is being a real pain at the moment. Its being really intermittent. I'm located in Ireland, I'll get in touch with the local NH dealer and see how it goes...
paul
08-10-2006 08:13:10
 Re: New Holland Square Baler Operators Manual in reply to dev, 08-10-2006 02:09:41
Ah, those intermittent problems.... Some days I wish the thing would just break totally, so a person knows what to fix!
Sorry I'm not any real help to you.
--->Paul
dev
08-10-2006 08:21:03
 Re: New Holland Square Baler Operators Manual in reply to paul, 08-10-2006 08:13:10
Couldn't agree more paul... Atleast if it broke completely I wouldn't be going around busting every fifth bail, its almost teasing me to keep going....
Cheers anyway.....
Chick
08-09-2006 13:25:41
Call CNH (Case-New Holland) Technical Publications. They have a couple of videos that explain the knotter operation, common mis-tie problems and adjustments to cure them. The Video shows the knotters in slow motion and takes any mystery out of them. The latest one I got from them, came on CD. It is titled "Square Baler Knotter-Operation, Adjustment, and Troubleshooting" The phone number is 262-636-7164. Ask for Larry.
BobMo
08-09-2006 08:14:47
You also BUY the knotter manual (only) for your baler..... ..... Good Luck
paul
08-09-2006 08:06:58
Since it's copyrighted, only a very few would post such on an open web site..... ..
The manual is cheap from NH, and a lot easier to access when you need it. ;)
--->Paul
Ken Macfarlane
08-09-2006 12:50:06
 Re: New Holland Square Baler Operators Manual in reply to paul, 08-09-2006 08:06:58
I have a photo copy of it at home, the originals disintegrate quickly in a tractor cab.
paul
08-09-2006 13:21:44
 Re: New Holland Square Baler Operators Manual in reply to Ken Macfarlane, 08-09-2006 12:50:06
I do the same, more so with the planter. Got several copies of the planter settings in 2 of my tractors right now I'll bet.
I'm sure someone can supply a file or photocopy of the pages as well. I believe I have seen them posted here over the years once or 2wce.
All I mean is, no one will set up a web site with the entire manuals available for free - eventually the copywrite folks will catch up with that sort of thing. Just not going to happen. There is no point & click for this sort of thing, and explaining the why of it.
--->Paul
