450 NH knive replacement
mitchp
08-09-2006 06:15:03
Do they make any replacement for the rivets that hold on the knives on the sickle bar for my 450 NH mower? I've heard of small bolts, but do they work good, and anybody know the part number to purchase them??? How is the easiest way to remove the old rivets?
Harley
08-09-2006 19:07:23
 Re: 450 NH knive replacement in reply to mitchp, 08-09-2006 06:15:03
Yep, them little bolts are the cats meow. Any farm supply store should have them, that's where I get mine. I always carry a punch, chisel, hammer, and ratchet with 7/16 socket and about 4 minutes you can change a ledger plate and you're back in business. Best invention since a pocket on a shirt. Harley
mitchp
08-09-2006 21:41:17
 Re: 450 NH knive replacement in reply to Harley, 08-09-2006 19:07:23
well i went ahead and bought me the rivets from new holland, how is the easiest way to flatten them out, i put it through the hole, laid it on the vise and had to hit it about 30 times to get it flattened out and the knife tight
Harley
08-10-2006 08:33:31
 Re: 450 NH knive replacement in reply to mitchp, 08-09-2006 21:41:17
You need a bigger hammer. Two or three times should be all you need. I remember using the rivets, and they are all right but they are a lot harder to work with. Espicially when you are out in the field. You have to carry a piece of steel for the bottom of the rivet to sit on, Being down in the hay with the ( down here anyway) ticks and chiggers, and beating around on uneven ground with that stuff, I just don't think you can beat the bolts. You don't even have to lower the bar to work on it. Standing up beside it, and get-er-done. Harley
mitchp
08-10-2006 12:21:29
 Re: 450 NH knive replacement in reply to Harley, 08-10-2006 08:33:31
what size bolts is it?? what length would i need?
Harley
08-10-2006 17:51:17
 Re: 450 NH knive replacement in reply to mitchp, 08-10-2006 12:21:29
I think they are 1/4 inch by about 3/4 inch long. They have a carriage head with a screwdriver head and special little serrations right below the head that self-lock into the bar when ya drive them in. the nut is self locking so it don"t come off. They come in packages of about 50 bolts and nuts together.
mitchp
08-10-2006 21:14:47
 Re: 450 NH knive replacement in reply to Harley, 08-10-2006 17:51:17
one more thing and i'll leave you alone, do i get them at the dealership? any way you can get me the part number???, i asked my dealer about it and he had no idea what i was talking about, said that rivets was the only thing i could use
banjo
08-12-2006 09:30:38
 Re: 450 NH knive replacement in reply to mitchp, 08-10-2006 21:14:47
any tractor supply,atwood, equipment dealer should have them. one drawback is you will have to replace the hold down clamps with ones for bolted sections. will need 2 sizes of bolts. londer ones for the head of the bar. I don't have the part numbers but if you buy the knife sections they should have the bolts also.
driz
08-25-2006 23:57:14
 Re: 450 NH knive replacement Do The Make Them For in reply to banjo, 08-12-2006 09:30:38
Are these bolts workable for any type sicle mower? I just pounded 60 of the things and they are a major PITA. How do you get the bolt heads flat enough to clear the guide clamps? I had to grind mine down almost flush.
