 We wrap most all of our hay now and it is a very good substitute for silage. I am very much into the fact that if you make good quality feed, you need less of it and your animals will be healthier and grow faster. That said we use a trailing wrapper. They both have their good and bad. The trailing wrapper uses more plastic and is slower bales per hour than the tube wrapper, but it tends to keep the bales better, ensiles the feed much better, and each bale is its own intead of getting a hole in the tube and spoiling several bales. Also it is much easier to transport the bales after they are wrapped with a hugger and a wagon and not break the plastic, the tuber has no way to move the bales after they are wrapped. I also think that the bales take up less space individually wrapped as you can stack them two or three high in an area instead of having them all along a fence somewhere. The tuber is faster and uses less plastic, but tends to get more holes because of the less plastic. Splits develop where the bales meet and there is more oxygen in the tube to burn so it does not ensile as good as the individual bales do. Bottom line to wrapping, just like anything, you get what you pay for and the time you put into it. If you want good quality feed, and put the time and money into it, the trailer wrapper is the best. If you want speed and less plastic expense, and can tolerate some bale loss, the tuber is better. You can see which way I lean, I like the Vermeer 3500 hay wrapper, and I really do not like the tubers. I know a lot of people tube hay, and it is cheaper to do that way, but I dont think they are getting the quality they think they are. Just my 2 cents, I think it is the best way to make hay, no matter what you use.
