Hi Ken, Yes, I'm going with separate gear. We bought a Kuhn 43XX? Masterdrive rake last year. Can't remember the exact model number, but it's about 14' working width, fully mounted. I'm fairly happy with it so far. It's well built and works fast. I don't really like the way it makes a row in some ways, as it tends to put more hay in one side than the other, which can be a pain with a round baler. It's also a lot like a hoover vacuum. It gathers up every stick, stone and pebble on the field, and there doesn't seem to be any way to prevent that. It either takes everything, or if it's set higher, it misses hay... However, I'm just so glad to be able to go and rake a field quickly and without incident. I'm still using the 254 as a conventional tedder, which it works fairly well at, although it's not very quick. I would rather go to a 4 basket tedder, simply to cover more ground quicker. I like to cover 20-30 acres a day, and the tedder is slow, and way to slow to do both that and rake in the same day.... I was only half kidding about selling the 254, but would if you're interested. If so, shoot me an e-mail. We'll talk. I'm in Cape Breton, but if you're not in a panic, it can be moved. Take care. Rod
