New holland 68 baler manual
soonerca
08-07-2006 05:16:31
My bales are coming out loose. I was told that it is an easy adjustment with the manual. Does anyone have an extra manual or copy for the NH 68.
Chick
08-07-2006 18:43:48
 Re: New holland 68 baler manual in reply to soonerca, 08-07-2006 05:16:31
You can find a manual on ebay, or you can call Case-New Holland Technical Publications, for one. Or, just go to the NH dealer and get them to order you one. I have one, but want to keep it.
To tighten the bales, crank down the 2 handles on the back of the bale chute, until the bale is the weight you want. If you need any sheet metal parts for the baler, send me your email address. I have a baler I have abandoned, and it has many new sheet metal pieces (galvinized) that I had made in a local shop.
GregC
08-07-2006 11:41:09
Most likely you just need to tighten the bale tensioners, that's assuming you haven't tried that already. You can do this by turning the two handles at the rear of the baler chute clockwise, be sure to turn both the same number of turns. If there are more problems just post back, there's alot of people here willing to help while you're waiting for your manual.
GregC
08-07-2006 11:40:51
GregC
08-07-2006 11:35:15
Shovelman
08-07-2006 07:46:48
Call CNH Publications @ 800-635-4913. They will have what you need.
Scott
BobMo
08-07-2006 07:38:21
I'd be surprised if you couldn't buy one from your local NH dealer.....
Rexalot
08-07-2006 12:11:57
 Re: New holland 68 baler manual in reply to BobMo, 08-07-2006 07:38:21
Myth buster time:
Both bale chamber tension handles/springs need to be set at the same number of turns all the time. This is not true. Your model 68 is old and likely the springs will not be at the same tension under load.
Start by cranking them down until there is no play in either threaded rod and the handles just begin to compress the springs. Next, start baling, you need to get some hay in the chamber to set your bale weight. Adjust down both tension springs. (Your first bale on an empty chamber will likely be long and very light. The next bale will be better.) Turn them the same until you get the bale weight you want. Once you have the weight you want set, you can then adjust the bale tension to assist in making the bale square should you get consistent bananna's (one side of the bale is longer than the other). Tighten the spring that is on the long side (preferably) or loosen the spring on the short side. Do this in 1/4 or 1/2 turns at a time until the bale squares. You can just do one side or the other.. in the end neither spring will be at the same number of turns.
Your bale length should be limited to 3 or 3.5 foot long. You can do longer but you'll have more handling problems (breakage due to bananna-ing)if they aren't tight. Hopefully you know how to set length.
Here is how I set mine, once I had an ideal bale made I measured the distance from the top of the threaded portion of the rod to the top of the tension spring adjustment handle. I wrote this down for each spring. I then cut a foot off an old yard stick and keep that in the baler's tool box. I set my springs to this measurement prior to baling then adjust if necessary.
As for a manual, I would try Ebay. I got all mine there. If you have more questions post up.. you might also search for Kelly C's previous post's in the forum archives on the model 68. You'll be able to find a link to his website. He has useful info on the model 68 there.
