Vermeer 605G round baler???
BCnT
08-04-2006 21:27:27
howdy...kinda new to this board and got a question...got a Vermeer 605g for sale close by...was wondering if theyre any good...only experience i got is with square balers and that was 35 years ago.
also what can i expect to spend on bearing and belts...its sposed to be working but i've heard that before.
thanx
chuck
Joe(TX)
08-10-2006 14:18:36
 Re: Vermeer 605G round baler??? in reply to BCnT, 08-04-2006 21:27:27
It sounds like pcy1066 bought one that was abused. I've had a 504G for 20 years and has given me few problems. Whoever had it before me must have had problems because of the graffiti on it. It was obvious they did not know how to adjust or run the baler. They apparntly never greased the pickup either.
Belts can run $800 to replace. Bearings around $25-30 ea.
Carp
08-05-2006 10:00:39
We have had a 605G for a lot of years (20) and have custom baled with it every year. They are good balers, but like any other peice of equipment can be abused. Like was stated earlier, check the chains, gear box and bearings. Also check the belts at the lacing. If it has been stoored outside a lot, the belts may be shot.
504 Baler Guy
08-05-2006 07:49:59
It is and open throat baler that makes up to a 6' in diameter by 5' wide. You can stop and tie the bale off at any diameter you wish. Things to check are wear in the pickup tine bars, gearbox, belts and bearings. If you do purchase the baler call Vermeer and they will send you an operators manual for free. That way you can adjust it. They are a good baler just remember that they are older
pcy1066
08-04-2006 22:22:11
aftera barn i had burnt i lost my newholland round bailor, so becsause it was cheap i bought a 605g, my advise RUN away from it, i now have another new holland round bailor, to many horror stories on the vermeer
