Need mower, is IH 990 a good one?
Frank Fox
08-01-2006 21:50:49
I just looked at an IH 990 mower/conditioner for sale privately. It looks to be in good shape to me. I don"t know a whole lot about mowers. My friends all use disc mowers but they have more money than me! It has a steel roller on top of rubber roller and they look ok. The guards look good. It is not banged up. He is asking $900. Any suggestions?
Thanks, Frank
Delbert
08-02-2006 05:33:15
 Re: Need mower, is IH 990 a good one? in reply to Frank Fox, 08-01-2006 21:50:49
They are a good machine but check the square frame on the left side to make sure it not cracked. If the frame is broke or cracked it will let the header sag and the chain will come off. But if it isn,t all beat up most likey it is ok. Check wobble box, run it if possible they are quit noisy but will do a good job. Doesn,t require a lot of horse power a m farmall will run them real good. Seems alittle high but if in good shape might be alright. I bought one 3 or 4 years ago for $500.00 not had much trouble with it. The frame mostly if cracked will be cracked just above the left wheel as you are standing behind the machine.
