Howse rotary mower
wkw
07-31-2006 20:07:41
I am a complete neophyte when it comes to all things farming. My indulgence into my wife"s interest in horses now has me living on 80 acres and rapidly trying to learn all the things required to keep the place up.
Because of the somewhat finicky tastebuds of my four-legged lawn ornaments I have paddocks and pasture areas I need to mow. I have been looking at rotary mowers. I recently bought an old IH B414. I recently came across a Howse (hope the spelling is correct) rotary mower for sale. It is a 6 ft model and has about 3 hours on it.
A couple questions for all of you. Can my tractor handle this mower and is this a good brand of mower?
I thank-you in advance for any knowledge and information you can share with me.
P.S. Can anyone direct me to a source of a spin-on oil filter adapter for my tractor. I am having a dreadful tme with leaking gaskets on the cannister type that is on it.
Ken W
Drumheller, Ab
IH2444
08-01-2006 06:12:24
 Re: Howse rotary mower in reply to wkw, 07-31-2006 20:07:41
Ken,
First the leaky oil filter. I think if you check you will find an extra rubber gasket down in the groove. remove it clean the groove good , new gasket and all will probably be fine with the oil leak.
I think the 414 will work the cutter ok if the grass is not too high. If it bogs you down too much in tall stuff, just take narrower swipes.
Howse cutters are ok, perhaps not the best brand but ok. I think they sell several different grades though, the heavier the steel is on the cutter the longer it will last.
Jonfarmer
07-31-2006 21:48:02
Yes, a 6ft cutter would go real good on your tractor. You spelled it right, and I have seen them before, they are not super duty cutters and are kind of an off brand, but if all you are looking for is something to clip the grass and light brush, then I'd say it might suit you well.
