shaft or flywheel moving??
Hayman
07-30-2006 14:05:10
You are going to have to find out if the flywheel is loose on the shaft or is the shaft actually loose in the front gear box bearing there.
The flywheel bore has a brass bushing in it that gets worn over time causing some play between the flywheel and shaft. Some play is no big deal.
However if your gear box input shaft is actually moving around causing oil to leak out of the gear box etc. then you have a more serious problem.
