loader tilt leak off
Hilltopper
07-30-2006 13:57:30
I have a 45 jd loader on a jd 70. I have rigged a pair of 2 1/2" dia. cylinders on the tilt of thte bucket. I bought them new 2 years ago. I have problem with the bucket tipping down under load and also when sitting with no load in it.I replaced the control valve with a new one last year and it makes no difference. It is very difficult to carry heavy bales on it as it wants to tip. Is it possible that the piston o rings in the cylinders are leaking by. I am beginning to think I should have bought larger cylinders as the bucket is tipped upward with the pull stroke of the cylinder which has less lifting force. Any thoughts?
Don-Wi
07-30-2006 14:36:34
 Re: loader tilt leak off in reply to Hilltopper, 07-30-2006 13:57:30
What brand are the cylinders? Some are made cheaper than others and even when new don't stnd up to heavy loads like on a loader. If you replaced the control valve last year and haven't noticed any leaking hoses, I would look into the cylinders.
What you could do is temporarily plumb in a ball valve, and once you have a load on it close it off and see if the load still tips. If you have quick-attatch couplers on the hose, disconnect them when you have a load on the front. That will either point to the control or the cylinders. As to which one, you will have to isolate them to figure it out.
Donovan from Wisconsin
old
07-30-2006 14:07:30
On most loader that type of problem is caused in one of a few ways. One is the valve leaking by, 2 is the cylinders by passing or 3 is a leak in one of the hoses. Or of course a little of all of them. Can be fun to figure out if its just one cylinder doing it also. I know I had the same sort of problem with my NH850 baler. I ended up rebuilding both cylinders
