just one of those days...
Don-Wi
07-30-2006 12:42:20
I ordered some new belts for our New Idea haybine and finally got them on Friday. After spending a good portion of the day in the sweltering heat and taking everything apart to get the inside one off because they are both double banded and not enough clearance to get the inside one. The outer one can I can slip in there, but the inside is a little more involved.
I got then jackshaft back up there only to find out the inside belts (went with single banded on the inside because the double banded are only available form AGCO) are too long, and the outside one is too short.
The good part is I managed to get the belts out without messing with the jackshaft again, but now we're probably going to have to eat the cost of the one double banded belt because it was a special order belt. The other good part is, the cost is still going to be cheaper than AGCO belts and with the single banded ones on the inside, replacement should be a little bit easier.
To top it all off, I left the tractor and heybine in the driveway over night, all the tools laying out everywhere, tool box open. We got over 1" of rain last night... Corn don't mind though and the 3rd crop is really gonna use it too.
Donovan from Wisconsin
Fahmah
07-30-2006 18:54:39
 Re: just one of those days... in reply to Don-Wi, 07-30-2006 12:42:20
Boy that sounds very familiar! Lets see after replacing knotter parts my baler was out of time. Struggled with that a bit finaly got it and then one side wouldn't tie. After tinkering for close to three hours everything worked GREAT oh but wait. The rain from a recent thunderstorm made it just soft enough that it took two tractors to get around the field in a couple of spots. Any of this sound familiar? We just keep plugging away though
two mile
07-30-2006 15:34:04
We have all had them. This is an unpredictable business. We don"t understand what it is that drives us to do these sweaty, hot, dirty, knuckle bustin" jobs. But we do, and somehow find satisfaction out of making something work the way it should, or even better than it was before. If we didn"t enjoy this stuff we wouldn"t put up with it. Rain in the toolbox is a small price to pay for help that it will give our crops. Keep looking for the bright side, and it will make the next challenging job even more enjoyable.
Randy as in Randy-IA
07-30-2006 16:55:49
 Re: just one of those days... in reply to two mile, 07-30-2006 15:34:04
Hi Two mile , It seems that the more years that go by the fewer bright sides come along .
Hi Don With that said it also seems as though whatever some people touch turns to gold and what others touch ...uuhhh ..doesn't . You seem to actually be one of the former from your past posts . Even those with the Midas touch have bad days so don't let it eat on you . I've found that the quest to save a few pennies almost alway's cost's more in the long run . Get the Agco belt ...You'll probably never have to replace it before the whole machine is worn out . It's good to look to the future but look realisticly (sp) . Good luck ...Randy
Don-Wi
07-30-2006 21:38:40
 Re: just one of those days... in reply to Randy as in Randy-IA, 07-30-2006 16:55:49
Actually, the dealer kida discouraged me and said "go ahead and run 2 single banded belts" And for the little we use it, I think I'm gonna go that route.
I REALLY don't feel like dropping the jackshaft again, it's about 40 pounds and akward as all heck. Then I gotta reach in a small access hole and get 1 of the (4) 5/8" bolts in that hold it up there.
The new belts from the other place are Good Year so they're just as good as the ones from AGCO. The 2 Agco belts would run right around $100 for the set. From Bachall Rubber they ran me about $30 for the set. Bit of a difference, and since we really only cut swamps with it anymore, it'll only be used about 5-7 hours/year, unless the Hesston goes down...
As far as my luck, it's been hit-n-miss lately. I'm also working on fixing the axel on the neighbor's Minnie-Mo disk we borrowed to work some plowing because our old JD just isn't big enough anymore. The trouble comes with the big water tank they've got on top, and the weak axel under neath that isn't designed for that extra weight. I was just pulling oput of the feild when the axel on one side, made of 2 peices of 3/16" channel iron welded in a box over the pipe axel, snapped off where it had once before and was poorly welded back on.
I got 2 new peices of thicker channel iron on Friday and welded them together. Now I gotta put them on the CNC machining center and put 2 holes through them, a 3 1/2" and 2", 26" apart. Then I gotta find a new peice of 2" thick wall tubing to put the axel stubs in and drill 2 3/8" holes in it for the roll pins. I should be able to bring it back in another 2 weeks, just in time to borrow their chopper boxes for straw...
08-01-2006 15:44:09
 Re: just one of those days... in reply to Don-Wi, 07-30-2006 21:38:40
See ? There ya go ! Good luck is all around you ! You have the friends and neighbors that are willing to give you a hand and help you out if need be . If that's not the " luck of the irish " I don't know what is ! The broken parts is minor . Be thankful for what ya have ! It's a load more than what I have . ...Randy
Don-Wi
08-01-2006 23:59:56
 Re: just one of those days... in reply to Randy as in Randy-IA, 08-01-2006 15:44:09
I guess when you put it that way.... I've been slowly working on my list of projects.
I still need to replace the clutch disk in the clutch pack assembly for their JD swather, after we borrowed one from their parts machine to fix the other neighbor's swather when it broke the drive chain and blew the clutch disk...(last year's oats) It's a good thing I have full access to 2 different machine shops right now, all I have to do is sponser the material.
I suppose you're one of those poor bastards who doesn't have anyone around willing or able to help out aint ya?
