18 Tooth Digger Pinion Gear
john_b06
07-25-2006 05:13:45
I need some help in finding an 18 tooth beveled pinion gear for an old post hole digger. Have no clue as to the manufacturer, only numbers available are cast into the square gear box, 5E499. The input shaft is 1-1/4 inch. Any help would be appreciated.
Don-Wi
07-25-2006 13:05:07
 Re: 18 Tooth Digger Pinion Gear in reply to john_b06, 07-25-2006 05:13:45
Google Martin Gear. They should have a gear in the right tooth profile, and if the bore isn"t quite right bring it to a machine shop to have them finish it.
Donovan from Wisconsin
john_b06
07-25-2006 13:43:17
 Re: 18 Tooth Digger Pinion Gear in reply to Don-Wi, 07-25-2006 13:05:07
Don,
thanks, will try martin.
