twine on NH 66 baler
jared hanson
07-22-2006 14:58:24
i need to know how to run the twine from the twine box to the needles and then the knotters
Leroy
07-23-2006 19:58:26
 Re: twine on NH 66 baler in reply to jared hanson, 07-22-2006 14:58:24
There are 2 tensioners on the box lid, 1 for each spool of twine, it looks like it would be good to run both strings under the tensioner on the left side of the twine box lid but DO NOT DO IT, it will throw the tension off and keep it from tying on the right side of the bale (TOO much pull on string, will not let knotter hold it). This is not covered in the operators manual but we found out by experiance.
Lloyd Llama
07-22-2006 17:04:48
Run two twines thru holes in side of box, and between the spring loaded pressure plates. Then thru the insulator on side of needle cover( bottom of baler). Then split twine and run a strand thru each of the insulators at the front of needle cover. Then thru the eye in each needle. Tie off the end on a convenient point on baler. Get baler running, feed in a little loose hay, and trigger knotter, Should feed twine into knotters, and be ready to go!
Nebraska Cowman
07-22-2006 15:32:24
once you get the twine threaded though the needles, add hay and trip the knotters to tie, That will put the twine through and ready for the next bale.
