cylinder
calling old
07-21-2006 04:12:09
I hate to ask for the 3rd time. We got the cylinder off the baler now what are the procedures for replacment of leaking seals?
Thanks
old
07-21-2006 05:21:53
 Re: cylinder in reply to calling old, 07-21-2006 04:12:09
I'll try to explain it. On the end that the ram comes out theres a set screw,that you need to remove. Then with a flat tipped punch you have to knock the end part in about 1/4-1/2 inch theres a lock ring in there that can only be removed after that part is pushed in. From there all you have to do is pull it part. If you need a picture of all the seals etc just drop me an e-mail and I can scan one I have which I used to rebuild my cylinders. Also be sure to use hyd oil on all the seals when putting things back togeather. By the way I'm always happy to help if I can
jughead 2
07-21-2006 10:07:55
 Re: cylinder in reply to old, 07-21-2006 05:21:53
thanks I will try that. I see the set screw-I will repost in a few days.
old
07-21-2006 20:50:51
 Re: cylinder in reply to jughead 2, 07-21-2006 10:07:55
I had my 850 out today baleing with it and the 2 rebuilt cyclinders seemed to work great. No more tale gate comeing open other then when I want it to do so. The fun part after you get the end drove back a little it the lock ring from there its a piece of cake
