NH 1032 Hydraulic Problem
Kelly MT
07-19-2006 22:22:28
My 1032 bale wagon pick-up chain stopps when a bale is picked up. Also I can't retract the pushoff rams. I noticed that the supply line to the push off control valve is cold and the pick-up line is very hot. The pump is making a by-pass like noise also. Starting up cold the small pump discharge line gets hat very quick, the large line is cool. All valves are in their proper position. Any ideas? PK
Jerry/MT
07-20-2006 10:29:16
 Re: NH 1032 Hydraulic Problem in reply to Kelly MT, 07-19-2006 22:22:28
That"bypass type noise" is probably a relief valve running open so there is probably a restriction in the discharge line from the pump. It's getting hot because you're just bypassing the pump output back to the reservoir and back through the pump so it's heating up. Is there a filter or screen on the pump discharge side of the system? If so look for a clogged filter or escreen, a kinked line, etc.
TimS
07-20-2006 08:32:49
This wagon has it's own self contained hydraulic system right?
Sounds like a blockage somewhere in the system, start by checking the filter and screen if it has one. Try and isolate where the blockage could be.
