Rear Dolly Wheel on PTO Driven IH No. 11 Hayrake
farmallhal
07-19-2006 16:52:13
I have an IH/McCormick model 11 PTO driven 2 point fast hitch hay rake I'm trying to get a restoration started on. One of the original rear dolly wheels has been replaced at some point with a boat trailer wheel with a 5 bolt hole pattern. The original and correct IH wheel is made from two halves which are bolted together to make a single wheel. The IH part nos. for the wheel halves are 457383R1 and 457384R1 if anyone has a cross reference book. The three hub mounting holes appear to be on a 5" circle. A 4.80 X 8" tire is the tire size for this wheel. Not having any luck as of yet finding a correct wheel. Would anyone know what other IH implement might have a similar wheel? Also, got an idea to check the old John Deere mowers which had a rear dolly wheel as to their size and configuration. I presently don't know what the hole pattern and diameter of pattern is for the JD wheel. Found a 9" wheel which might fit the hub but don't know at present if the pattern diameter is the same. The 9" wheel has traces of old yellow paint so it might have come from a JD implement. Any assistance in this restoration with ideas, possible parts or other information would be most appreciated. Thanks, Hal
