New Holland 271 loose wire
tycteach
07-17-2006 15:45:13
I have a New Holland 271 wire tie small square baler. It"s doing pretty good on heavier bales, but when I loosen the tension off to lighten the bales, the wires are not tight. What adjustment do I need to make to keep the wires tight no matter the length or the weight of the bale. Thanks in advance for the help.
bvomark
07-18-2006 06:36:42
 Re: New Holland 271 loose wire in reply to tycteach, 07-17-2006 15:45:13
Paul is right. Keep the tension on the bale chute to make the wires tight. If you need to lighten them up just make them shorter. Spongy loose bales are caused by not keeping the tension on the chute and not feeding hay fast enough. According to the manual on my NH 277 the bale should have at least 11-12 strokes of the plunger. If you have alot more than that though the bales start getting spongy.
paul
07-17-2006 18:54:05
Wire tie disappeared a long time ago around here. I have a 270 twine tie.
Nature of the beast, the tension adjusts the tightness of the bale. If you want lighter, you would need to shorten the length of the bale.
As far as I know.
--->Paul
