Info on JD corn binder needed
KEB
07-16-2006 13:16:24
Just acquired a one-row, ground driven John Deere corn binder. Other than being frozen, most of the mechanical parts look to be in pretty good condition. As near as I can tell, the chains are all intact, etc. However, most of the wood is literally falling apart. I've seen a couple pictures, and some discussions in the archives, but haven't been able to locate any other info. Would greatly appreciate any help anyone can provide, particularly with regard to patterns or good close-up photos for the wooden parts. A manual would also be great. Will gladly pay for copying, etc.
Thanks,
Keith
Ben in KS
07-16-2006 18:00:25
 Re: Info on JD corn binder needed in reply to KEB, 07-16-2006 13:16:24
Keith, Congrats on the binder, you'll have fun with it. I have several IHC binders and manuals, but no JD's. The original boards on all binders were basically 1X12 long leaf yellow pine. Good luck finding that! If you are unable to find existing boards to use as patterns, you might try to fabricate from scratch, based on any pictures or brochures you can find. They are essentially 5 to 6 feet long and taper on one side to a point. Good quality 3/4 inch plywood can be made to work too. HTH Ben
KEB
07-16-2006 19:43:37
 Re: Info on JD corn binder needed in reply to Ben in KS, 07-16-2006 18:00:25
Ben
Thanks for the info. Some of the smaller peices are probably sufficiently intact to make patterns, but the long ones that run down to the points are in small pieces. Haven't been able to find a good detailed picture yet, still looking.
Keith
Leroy
07-17-2006 04:44:46
 Re: Info on JD corn binder needed in reply to KEB, 07-16-2006 19:43:37
Wrote a reply last night but it did not post. Where are you located? Would you be close enough to northwest Ohio to look at a binder and make your own paterns? do you have a bundle carrier? I have one that is stored and in good condition, oil up and would be ready for work but hasen't been used in years. Also have friend that has one that is used every year. I do have two different manuals here someware (?). I think John Deere should be able to come up with a manual, try that first before copying any Deere manual. If you still can't get one post back and something can be done.
KEB
07-17-2006 07:05:51
 Re: Info on JD corn binder needed in reply to Leroy, 07-17-2006 04:44:46
Leroy,
Thanks. I"m in Colorado, outside of Denver. There"s a John Deere dealer not too far away, so I"ll try them first.
Yes, there is a bundle carrier (I assume that"s what it is, its a flat sheet of metal on the back with a conveyer chain), but the shaft that drives the chain is bent, and I can"t quite figure out how it"s supposed to be arranged.
First task will be to soak everything in penetrating oil & see if I can get the mechanism to free up.
Keith
KEB
07-17-2006 07:03:52
Leroy,
Keith
