McConnel S12 Double D backhoe controls
Mark Dickinson
07-16-2006 07:12:05
Is anyone familiar with the McConnel Hy-Fi controls fitted to Double-D backhoes, (I believe these were sold in the US under the name Howard)
I have just aquired one of the backhoes and an puzzled by the twin joystick controls, as it doesn't possible to operate one lever independantly of the other as they seem linked by a central shaft?
Does that make sense?
Any help or advise would be much appreciated
Mark
RodInNS
07-16-2006 16:52:30
 Re: McConnel S12 Double D backhoe controls in reply to Mark Dickinson, 07-16-2006 07:12:05
We used to have a hy-fi valve bank on our 6/14 power arm. It's close to 15 years since we had the hy-fi controls though. Those valves gave more trouble..... always blowing o-rings and leaking, or not functioning. When they did work, they worked nice. As I recall it was never a problem to use 2 functions on the same lever, and for that matter, to run 4 functions at once if the oil supply was there. We ended up installing a commercial valve bank with levers to get clear of the problems.... but I did like working with the hy-fi controls. Unless there is something different about how the backhoe controls were set up compared to the power arm, I'd say there's somthing wrong with yours. HTH.
Rod
