Vermeer 504C - Easy Start Cam Kit
KenB_222
07-15-2006 14:05:23
I received a manual from Vermeer on my 504c. It shows an Easy Start Cam Kit for s/n 2681. My s/n is 1327. What does this kit do? Can I add it to my baler. Would it make much difference in starting bales? Can I get this kit from a dealer?
504 Baler Guy
07-15-2006 16:36:35
 Re: Vermeer 504C - Easy Start Cam Kit in reply to KenB_222, 07-15-2006 14:05:23
I don't remeber exactly what that kit is, but since your serial number is lower than listed that kit is not for your baler. I make sure that there are bolts in the density spring chains that stop the belt tightener from going all the way down when empty. Your dealer kind find out more info on this kit and order any other kits or parts for your baler.
KenB_222
07-16-2006 04:59:16
 Re: Vermeer 504C - Easy Start Cam Kit in reply to 504 Baler Guy, 07-15-2006 16:36:35
So, when starting a bale, the belts shouldn't have any tension? The bolts are in the chain, but don't contact the Bale Tightener Chain roller. Curently the belts always have some tension. How can I tell which link to put them in?
504 Baler Guy
07-16-2006 09:51:53
 Re: Vermeer 504C - Easy Start Cam Kit in reply to KenB_222, 07-16-2006 04:59:16
The belts should be loose at start. The bolt should hit before the density spring pulley at bottom. Put the bolt in a link that gives you slack belts at start. There are to way to move the bolt. Bale a bale and when the bale moves the belt tightener up that will allow you to move the bolt down. Or jack the belt tightener up with a com-a-long (sp?).
