Spring steel in pitman arm
marvin
07-14-2006 10:11:53
I have an older IH rear mounted sickle bar mower (Model 21) that I have mounted on my SUPER A. I was told that the piece of sheet metal that connects the bearing on the end of the pitman to the wooden pitman arm is spring steel. I did not realize that this was the case. Does this require any special consideration when welding on this?
Where can you get spring steel this thickness?
Bob
07-14-2006 21:23:59
 Re: Spring steel in pitman arm in reply to marvin, 07-14-2006 10:11:53
Can't New Holland supply that part anymore?
A Deere #5 mower uses a similar part, #Z9340H, still available, and priced a little over $30.00.
Have you checked with the CNH dealer?
