Woods cutter
Lee Peterson
07-14-2006 00:37:57
We have a Woods cadet 72 rear mount rotary cutter. the gear box is leaking badly. can anyone fill me in on how to change the seal in the gearbox?? any info would be helpful. thanks in advance!
Oldmax
08-14-2006 07:03:40
 Re: Woods cutter in reply to Lee Peterson, 07-14-2006 00:37:57
One of the nost common mistakes made with gear boxes is mist people overfill them .If you put too much oil in them will blow out seals a friend of mine checked oil in my kingkutter brush hog 5' hayside and filled up with oil when oil got hot blew seals "make sure only fill to fill hole" . is not that much expense but down time and labor cost .
flapaul
07-28-2006 18:17:14
I have a woods 60 inch bushhog . just down loaded an exploaded diagram and assemble instructions from the woods equipment co web site. might try that for starters.
Leland
07-17-2006 01:33:52
Find an good welding -blacksmith shop ,usually you need heat and a big puller to get the blade hub off and they can do a better job with out destroying everything else .
Robert in W. Mi.
07-14-2006 11:55:53
I have the same model, and it's been through hell!! Mine started leaking a couple years ago so i decided to fix it. I tried but couldn't get it apart, as the stump jumper ect.. is rusted on so bad... I said the heck with it, and just put a tube of cheap grease in it every once in a while...
It's been going like that for a couple years now, and looks like it's going to stay that way... It gets lots of rough use too...
Robert
IaGary
07-14-2006 05:37:58
Should be pretty staight forward.
Make sure there are no bearings going bad,that wobble,that caused the seal to go out in the first place.
Then just pull the pulley or pto shaft off and you should be able to slide the new seal over the shaft after pulling the old seal out.
Clean the shaft before sliding the new seal on.
As I said before check your bearings.
Gary
Craig in MO
07-14-2006 05:02:41
third party image
I have an M5 Dixie Cutter. If they are the same gearbox I can send you the instructions.
Lee Peterson
07-14-2006 06:01:01
 Re: Woods cutter in reply to Craig in MO, 07-14-2006 05:02:41
thanks guys but mine is the seal ,if i am right, on the bottom side that lets the oil leak down underneath on the blades or into the big circle that the blades are hooked to. looks like that circle will have to come off.where can a guy get some kind of illustration to show what to do? thanks for your help. any would be appreciated.
IaGary
07-14-2006 06:22:54
 Re: Woods cutter in reply to Lee Peterson, 07-14-2006 06:01:01
Should be able to see some kind of bolt or set screw attaching the pan to the shaft.
If you have a loader turn it over or stand it on edge and take a good look.
Gary
