Tractor size for NH 488 MOCO
CharleyFarmall
07-13-2006 14:11:28
I have a 50hp ( 43PTO) compact 4wd tractor - weighs a bit over 5000 pounds - I was looking at a 488 today with good rollers and in pretty good condition. I have rolling terrain. Will I be ok or should I stick to finding a good 472??
Thanks
p8ntball329
07-15-2006 12:13:20
 Re: Tractor size for NH 488 MOCO in reply to CharleyFarmall, 07-13-2006 14:11:28
We have used a NH 488 on our Super M. Thats only about 42 hp.
Tony
Ken Macfarlane
07-14-2006 15:58:52
I have a 53 hp (42 pto) hp compact that weighs 6500 lbs and I drag a NH489 around in fairly rolling terrain. It is shy on power on the up hill, great on the flat and downhill.
On a flat field I run 6.5 mph with the AC on and it is fine. On the hills my engine temps climb and she struggles so I have to drop to about 4 mph.
The other tractor we mow with is a Case / IH 585 52 pto hp and it does about the same on the hills.
CharleyFarmall
07-14-2006 05:10:45
Thanks for the replies!
RodInNS
07-13-2006 18:48:41
I think you should be OK. Just watch out on the turns when you're on a hill. Use common sense and you won't have a problem.
Rod
Lemonl
07-13-2006 18:46:19
I've used my 488 behind a Massey Ferguson 165 (about 45 hp or so)on rolling land with no problem. I don't know what the significance of the "compact" might be, but I'm sure lots of guys on here do! (By the way, the 488 has been a good, reliable machine for me.)
phillip d
07-13-2006 17:08:03
we have a 4610 ford (about 50 hp) we sometimes run our old 1327(9' cut) deere with,it is alittle slow in heavy down hay,but can run right along in regular going,phill
wolfman
07-13-2006 16:35:32
Likely very little difference in weight of the 488 vs the narrow one. Power is not an issue. Hang a set of wheel weights on her and cut a wide swathe.
old
07-13-2006 14:44:43
Don't know that model but I can say I use a NH460 and pull it with an Oliver 77 and it does real good so I would think you would be ok. The 460 is a 9 foot cut by the way
