JD 336 baler
BilTex
07-13-2006 12:49:51
Needles bring wire up and leave a loop, it is not cut or twisted (Cutter and twister both miss the wire, the side away from the pickup) We have put new rollers underneath, adjusted the needles, cleaned out cross-tube, changed the wire, oiled the wire, and said all the bad words I know. Can anyone help me???
BilTex
07-15-2006 05:19:55
 Re: JD 336 baler in reply to BilTex, 07-13-2006 12:49:51
Thanks for your help! We made the bales lighter and drove a little slower, made it work pretty well. This was the first time we had used this baler since putting a plastic liner in it. Also, we got our old Oliver 720 baler out of the shed and baled over 600 bales without a miss.
Tx Jim
07-14-2006 04:16:08
Be sure the needle rack pivots are snug so needle rack can't move side ways. The needle when up in tying system should be within 1/8 of inch from twister shaft and just barely clear nose of gripper as gripper shifts from one side to other. The bolts that hold needle will handle this adjustment. Tx Jim
MN Bob
07-13-2006 15:46:36
I gave a twine type. The manual does not have just what you described. One says wires not twisted together. Check; foriegn material in twister assembly; needles not adjusted properly; springs frozen in gripper drive tube assy; twister hooks retarded beyond max limits.
If you send me a picture of more description I may be able to help more. Bob
[email protected]
