NH851 - How to straighten the bars?
RFox
07-10-2006 12:43:45
Any suggestions on how best to straighten slightly bent bars on a NH851 round baler?
Thanks!
T.C. in Tx
07-10-2006 19:25:13
 Re: NH851 - How to straighten the bars? in reply to RFox, 07-10-2006 12:43:45
I used a NH 852 for nearly 20 years. I have straightened many bent tubes. The best method I found was using an old chisel plow that had a tube frame. Put the bent bar inside the tube and then use a longer piece of pipe over the bent tube sticking out for leverage and tweak as necessary. You will be surprised how straight you can get the tubes. And if you use a long enough cheater pipe it is very easy to do. Usually, I would place the bent tube into the plow tube up to the point where it is bent. That is where you need leverage to bend it straight.
Erran
07-10-2006 18:25:56
Hey if you have a manual i do belive i shows you how to do that.
old
07-10-2006 13:53:35
Best way is to replace them, but if that isn't an option then I would say a good big shop press
