How to make a tight bale NH850? (Allan?)
Kelly C
07-10-2006 12:07:37
Need some tips on how to get the bales tighter. I was not happy how they came out.
Way to loose.
I would assume that the chains can lossen up with wear but also maybe I didnt use it right.
Any info on better bales out of a chainer would be helpful.
Carp
07-12-2006 09:59:36
 Re: How to make a tight bale NH850? (Allan?) in reply to Kelly C, 07-10-2006 12:07:37
I have very rarely saw an 850 that made a bale that someone would be proud of. Now that is just my experience and not a bash on chain bales. The first chain baler that I saw make a good bale concistantly was the 855.
Now we use a Massy 1560 (Vermeer 605G) and a Vermeer 505I. Makes a square tight bale at what ever speed you want up to about 7mph. Just don't try to bale any fence posts with them.
troy1985
07-11-2006 21:16:06
i noticed frome using a 851 nh that the bigger the windrow the tighter the bale...and the big windrow and faster helped me make tight rolls of hay
Ross
07-11-2006 19:10:05
Out of curiosity when your old IH baler would start the bale did it make a tighter bale than your NH chain baler? I'm just wondering if the older belt balers could still make a decent bale.
Kelly C
07-12-2006 04:40:27
 Re: How to make a tight bale NH850? (Allan?) in reply to Ross, 07-11-2006 19:10:05
Old IH241 did make nice bales. The problem with the old belt baler was it decided not to work when I had 20 acres of the best hay down and it wouldnt start a bale. All the hay just plugged up at the compresion roller. hay got too dry.
Too dry or too wet gives them fits.
I had to square bale 900 bales in a day to stay ahead of the rain. Not fun!
A chainer will eat hay no matter what.
So until I can pay for a Vermeer 504 open baler its a chainer for me.
kyhayman
07-11-2006 16:33:29
Slowest gear you got, fastest PTO speed you can maintain, and tight as you can get the springs.
Allan In NE
07-10-2006 16:10:51
Hi Kelly,
Speed your PTO up to 540 rpm and keep it there.
You might have to drop a gear and/or tighten the springs like old has told you.
Allan
old
07-10-2006 13:52:14
Kelly, I'm guessing you don't have a manual do you?? Well I do and if you want info I can scan pages for you. Now to your question, if you want tight bales theres a number of things you can do. One is to slow down, my self I had to speed up because my bales where to tight and where weighting around 2500lbs. Yep I use an 850. You can also tighten the springs which will make them tighter. I haven't looked in the manual lately but they list 3 or 4 things to do to get them tighter
Luke S
07-10-2006 13:28:18
I don't know about a chain baler, as I have a hesston 5500, but with it, if you drive too fast the bale's get looser. Dringing a little slower helps, also as the other poster said more string on the bales. On mine you can adjust the tension on the string and I could see if it was not enough tension that wouldn't be good either. And last, I don't think you are going to ever get real tight bales out of a chainer. Every one I have seen around here makes some bales that are a lot bigger than mine, but mine weigh just as much or more.
Gene-WI
07-10-2006 12:46:36
Bale while the hay is a little tougher or early in morning or later in evening while dew is on. Also putting more wraps of twine on when tying helps.
