Flail mower vs. Bush hog?
Steve O'C
07-09-2006 09:32:37
Does anyone out there now the difference between a flail mower and a bush hog type mower? I have about 10 acres and want to cutt it with my MF65 tractor. Thank you for the help. Steve.
Bill in NorthCentral PA
07-09-2006 19:25:44
 Re: Flail mower vs. Bush hog? in reply to Steve O'C, 07-09-2006 09:32:37
I think the answer lies in what you will be mowing. We brushhog grass, but they are really the tool to use if you are cutting heavy grass / bruch. The flails as I understand are better on grass only situations. For what its worth, our brushhogs take a beating and keep going. My welder brother just completely built a new "body" for our old gearbox and associated components.
Gerald J.
07-09-2006 11:18:09
I don't have a bush hog mower. I have a JD flail mower. It uses the same knives as a JD corn chopper that is several times wider. In tall and heavy grass it can take all the PTO power my MF-135 can muster at 6 mph. That's mowing 6' 3" wide. For heavy cutting, it takes slowing the ground speed or narrowing the cut.
The finish of the flail mower can be a little rough as the knives swing in a circle about 18" diameter and there's just one per mowing position so at 6 mph ground speed each gets to the bottom just every 4" and that leaves a scalloped finish.
My flail mower throws the clippings back and up. I have to watch the wind direction to keep from being covered in clippings.
Gerald J.
Don-Wi
07-09-2006 10:44:15
A flail mower has a bunch of knives on a drum, almost like a reel type mower. Bush Hog's are like a regular lawn mower, except much larger.
I would take a flail over a brush hog because they tend to shred better, and it's less weigth hanging so far out. I've got limited experience with either one though, so others may be able to give better insight.
Donovan from Wisconsin
supergrumpy
07-09-2006 10:38:49
from what I have seen, bush hog type mower is the way to go unless you have some other considerations
road guys use flail mowers where there is danger of rocks and debris being tossed, I have been told that flails really suck up the horsepower
Matt from CT
07-09-2006 21:43:02
 Re: Flail mower vs. Bush hog? in reply to supergrumpy, 07-09-2006 10:38:49
Kind as of an insomoniac aside...
Our Town Highway Department bought a flail mower on an articulating arm about 21 years ago, replacing the old sickle bar mower.
Blows through the weeds, grass, small brush, etc and can conform to the roadsides much easier than a sickle.
Last year, they replaced the 20 year old rig. Same the size mower...but much, much, much bigger tractor. My gut says they went from a 35 HP Utility tractor to a 95 HP small Agricultural tractor...it was dramatic.
Talking to guy on the Town crew who runs it, they simply couldn't believe the performance difference --
With the old tractor they where regularly replacing broken flails -- because the old tractor just didn't have the ooomph to run the implement right...it just had the minimum HP spec'd. You'd think running slower would be easier on the flails...but it's not for their application.
The new tractor has the proper HP...seldom do flails break. Between not taking time daily to replace them and being able to go through stuff at a faster speed and not having to backup sometimes to make 2 or 3 passes...they did in 2 weeks what normally took all summer.
Which kind of gave the Highway Foreman the good kind of problem -- he suddenly had a guy freed up and nothing planned for him to do. They can whack the roadsides twice a year instead of once for less manpower, less maintenance, and I wouldn't be one bit surprised if it's less fuel despite the bigger tractor because they can get the job done so much faster.
