tying plastic twine
hayray
07-08-2006 20:10:16
Started using plastic twine this season and either the knot connecting the balls comes apart about half the time or the knot gets bunched up on the bill hook. Using bale baskets so I am into the fifth bale by the time I notice it. Any ideas on the best methods of tying and why is it geting caught up on the bill hook?
Ray
RickL
07-10-2006 05:06:44
 Re: tying plastic twine in reply to hayray, 07-08-2006 20:10:16
always used square not pulled real small trim off excess right into the not,no problems normally and I also run the 7200 per single roll and this makes for alot less ball switching also
hayray
07-10-2006 14:46:50
 Re: tying plastic twine in reply to RickL, 07-10-2006 05:06:44
Were do you get 7200 in a single ball?
Ray
RickL
07-10-2006 16:23:50
 Re: tying plastic twine in reply to hayray, 07-10-2006 14:46:50
Bridon poly twine in the 170knot strength,if you can't get it let me know I get it by the pallet,direct from the company. I am not sure if any other not size comes in it or not as 170 knot is all I ever use. Normally local stores etc only handle the 140 knot stuff that just doesn't cut it for me.
Chick
07-09-2006 20:08:18
Never heard of anyone useing a sheet bend. When I worked at the MF dealer, we always used a square knot, pulled down real tight, and trimmed. It worked about half the time. It has never worked on my New Holland balers, so i will try a sheet bend.
hayray
07-10-2006 23:06:45
 Re: tying plastic twine in reply to Chick, 07-09-2006 20:08:18
I tried that sheet bend that Dave showed me and that is a way better knot. I had bad luck with the square knot even after I tied the liven hell out of it.
kyhayman
07-09-2006 17:13:20
No matter what knot I use, or how I tie it, my baler (336JD) misses one tie every time it changes balls of twine (yes, they are good knots I do rapelling and they are either square knots or bowlines) Just a simple miss, no problem, picks up on its own the next time. My though has always been that the knot weakens the twine to the point that the twine strength wont take the bale tension.
hayray
07-09-2006 18:41:35
 Re: tying plastic twine in reply to kyhayman, 07-09-2006 17:13:20
I have to rethread mine after the twine comes apart - no needle twine left in the twine holder.
WyoDave
07-09-2006 18:55:25
 Re: tying plastic twine in reply to hayray, 07-09-2006 18:41:35
I always had the same problem. Always used a square knot and it always came untied. When I got the new 348 manuals I looked through and saw what knot Deere recommended, and started using it this year. Haven't missed one yet. I can't explain the knot and the manual is in the shop and I can't remember the name of the knot. I'll see if I can remember to get it tomorrow.
David
WyoDave
07-09-2006 18:59:35
 Re: tying plastic twine in reply to WyoDave, 07-09-2006 18:55:25
It just came to me. Its called the sheet bend knot. Follow the link for the how to. Its worth a try for your baler, it sure solved the problem on mine.
David
hayray
07-09-2006 19:50:32
 Re: tying plastic twine in reply to WyoDave, 07-09-2006 18:59:35
Dave,
that link you posted is pretty cool. I went out to the barn and grabed some twine and sat here praticing while that picture rolled through the steps.
thanks,
Ray
hayray
07-09-2006 19:42:03
thanks Dave, I will check it out. My manual just has a simple square knot.
Chick
07-08-2006 21:59:38
New Holland has a different bill hook for plastic, than the sisal uses. The hook itself closes more to grip the plastic better, as the plastic tends to flatten easily. I can tell the difference between the 2 of them, but it is hard to explain, in writing anyway.
Errin OH
07-08-2006 20:59:29
In my ford (NH sould be the same) I just tie a square knot, pull it real tight and trim down to about 1/4".
However check for a groves in your needles. I had one that would grab the knot and break the twine. It would tie the end in the twine holder but with the other end loose the swipe arm wouldn't clean it off the bill hook. As the bale pushed out it would tighten up on the bill hook and appeared to be tied to it.
old
07-08-2006 20:46:28
Need to know the model and brand of baler to be able to help. I know on the old JD-14T they make differant bill hooks for plastic
Ken Macfarlane
07-10-2006 07:34:30
 Re: tying plastic twine in reply to old, 07-08-2006 20:46:28
If I have the tension up hard our JD 336 will pull apart the square knot changing balls. Normally no problem unless the knot lines right up into the knotter. Our twine disk timing is off a fair bit but ours doesn't adjust, still ties beautiful on sisal and all plastic thicknesses.
We did have to really mess with the needle clearances and the wiper clearance.
