NH 68
Bret4207
07-07-2006 12:25:15
Decided to put new chains on the ol'68 HAyliner. I knew the timing was off a bit as I started having the plunger hit the safety block occaisionally last fall. So I did the chains and got the book out to time it. With everything timed per the manual the plunger just catches the safety block everytime I run it by hand. There's a bit of play in the knotter drive gear, but nothing big. Plus, the book says the needles should come into the bale chamber when the projections on the plunger are 1/2- 3/4" past the needles. Mine is more like 3-4". Could the timing mark be that far off?
Bret4207
07-07-2006 16:17:02
 Re: NH 68 in reply to Bret4207, 07-07-2006 12:25:15
Disregard. It was the the needle yoke rod. It had developed some play and 1 turn out put everything back in the right spot. The needle postition issue was a misinterpretation on my part. If the marks are lined up it has to be right 'cause it won't work any other way. Thanks.
mss3020
07-07-2006 12:44:19
You just answered your own question. If your plunger is 3 - 4" past the needles
that needs to be backed off to the 1/2 inch. then retime and your plunger shouldnt then hit the block. Its hitting the block becouse the needles are past that far. If not it would take the needles out.
