489 rollers and spacing shims
Spruce N Oak Me
07-07-2006 05:39:19
Like many others on the board, the rubber is patchy on my machine, There still appears to be good rubber depth. The spacing shims are out on one side but some still on the other. How much shim material can be removed? There seems to be a larger composite spacer there as well. Has anyone removed this to allow more adjustment for crimping?
Info for other cost questions - New rollers in Ontario range from $300 ea for used...$ 924 to $1500 each - new..not hard to see which dealer needs a holiday
Eddy in TN
07-07-2006 06:45:01
 Re: 489 rollers and spacing shims in reply to Spruce N Oak Meadow man , 07-07-2006 05:39:19
Owners manual says there should be the same number of shims on one side as the other. There are two shim thicknesses available (.060 and .015). Also, it stataes that "there should always be at least .015" clearance between the outer diameter and root diameter of the respective roll lugs". In the roll timing section:" make sure the rolls do not touch each other or bottom out". Removing the big spacer may not be an option. I am probably not supposed to post this here but I have a 489 for sale with excellent rollers for a little bit more that the price of new rollers. Hope this helps
CharleyFarmall
07-08-2006 03:37:56
 Re: 489 rollers and spacing shims in reply to Eddy in TN, 07-07-2006 06:45:01
Eddy,
Where in TN are you located. I am interested in the Haybine you have. I am not sure yet if I want to go with a 9ft but am definitely in the market. My farm is in Limestone.
Eddy in TN
07-08-2006 14:59:08
 Re: 489 rollers and spacing shims in reply to CharleyFarmall, 07-08-2006 03:37:56
I live in Giles County. If still interested I will give you a complete description. I can not send pictures.
