IH 100 7' 2pt mower
Lance R.
07-06-2006 19:34:52
There is an IH 2pt hitch model 100 mower coming up at an auction. I have a 560 with fast hitch and need a mower for it. What are the problems with this mower? Is it a pitman style or balanced head mower? Should I beware and stay away from it? What would be the max it should sell for if in very good shape?
M Nut
07-07-2006 06:19:00
 Re: IH 100 7' 2pt mower in reply to Lance R., 07-06-2006 19:34:52
I believe the model 100 was a small point fasthitch mower used on the super c through 230's. However, you could make a shim of some kind to make it work on the larger pointed fasthitch I'm sure. Just might not be quite field ready when you get it home to use with your tractor.
Loren
07-06-2006 23:18:04
Lance, I'd appreciate a couple dimensions from a link plate if you get it. I need to make the plate that bolts to the bottom of the tractor to raise the sickle. Thanks.
Doug in IL
07-06-2006 21:42:32
It is a balanced head mower. They are a good mower.
Doug in IL
07-06-2006 21:31:56
